delfinis38 1 Posted August 23, 2016 No not for the car, but want to cover two side windows of the garage so know one can peer in... I have a blind over the door... Is it a good option.... Or should I fit two frosted Windows. How easy is it go fit without getting bubbles in it. Quote Share this post Link to post Share on other sites
p0l1wrath 10 Posted August 23, 2016 Have tinted a fair few windows in the past, the flatter the windows the easier, so if your windows are completely flat you should be fine. When you peel the backing off to reveal the adhesive, you should spray with water and apply wet, then using a squeegee you remove the water from between the film and the window (starting from the middle, moving outwards). You should be able to get no bubbles in it at all. Plenty of youtube videos and online tutorials. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted August 24, 2016 Sounds like a good idea to me, and at least you can still look out of the window. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted August 24, 2016 I tried it once but was too tight with the water and it came out with loads of bubbles Quote Share this post Link to post Share on other sites
