It's not a Scirocco 10 Posted September 7, 2016 I have the corrado up on stands at the moment and thought about giving the whole wheel arch area a clean. I don't have a jet wash so can anyone recommend products to use. Most importantly what to use to seal the coilover struts and threads. Thanks Quote Share this post Link to post Share on other sites
delfinis38 1 Posted September 7, 2016 I have the corrado up on stands at the moment and thought about giving the whole wheel arch area a clean. I don't have a jet wash so can anyone recommend products to use. Most importantly what to use to seal the coilover struts and threads. Thanks I'd get the worst of the rubbish off first with a jet wash.. Your local car wash should have one. You can leave the muck on someone else's drive. Depending on how clean you want the arches to be then Jack the car up and do the rest by hand. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted September 7, 2016 i just used a hose & elbow grease Quote Share this post Link to post Share on other sites
It's not a Scirocco 10 Posted September 7, 2016 Did u use any sort of sealant afterwards? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 7, 2016 I've used this on quite a bit of my car, most of the engine bay etc http://www.ebay.co.uk/itm/like/221268304648?lpid=122&chn=ps&googleloc=9044905&poi=&campaignid=628893806&device=c&adgroupid=28312585266&rlsatarget=pla-193547817426&adtype=pla&crdt=0 Dries hard and gets into all the small areas Quote Share this post Link to post Share on other sites
It's not a Scirocco 10 Posted September 7, 2016 Many thanks Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted September 8, 2016 (edited) I took my arch liners off the front wings to give them a proper clean. Sprayed with Megs APC, but any good all purpose cleaner will do. Leave it to soak for a bit then used the auto glym wheel brush to give them a good scrub Rinsed with a hose pipe, then washed with normal car shampoo and a sponge (its the only time I use a sponge on the car) and rinsed again. Used a towel to dry and then applied a coat of colnite wax, and buffed off. Then repeated the wax process again. As for the coilovers, I would probably apply copper grease or white grease. To protect them Edited September 8, 2016 by sankysvr6 Quote Share this post Link to post Share on other sites
It's not a Scirocco 10 Posted September 8, 2016 Wow! Looks so clean. Nice work!! Thanks Quote Share this post Link to post Share on other sites
