VR6 Lee 0 Posted March 26, 2017 http://forums.vwvortex.com/showthread.php?7275737-WTB-ABS-Brake-Check-Engine-lights And the big question is will it work in a 1995 rado vr? Quote Share this post Link to post Share on other sites
Philly-R6 2 Posted March 26, 2017 Your 1995 VR6 has probably got the Teves 04 (I think) ABS system with the 535 919 235BA ABS lamp. This lamp has two connections - a 7-pin connector for the ABS lamp and a 2-pin airbag connector (unused inside the lamp). If the lamp is compatible with the ABS control module, you will more than likely have to change the plug on your existing harness to match the lamp - try to get the plug with the lamp (the pinouts are printed on the housing). Not sure how to plumb in the check engine light - the ECU emits the signal (on pin 5), but unsure where it pops out of the engine harness to connect it. Find the wire and this bit should work ok? On a side note, what does the left lamp indicate? The handbrake/fluid level state would still be displayed by the normal indicator under the dials. Quote Share this post Link to post Share on other sites
