harrisvr6 0 Posted July 16, 2017 My Divers side window has been out of action for some time. It just stopped working one day, then after ages, I pressed it one day and it worked. Then died again. Ages pass and then when I had some previous work done they fixed it, but it didnt last long either, when I asked them about it they said they moved the motor about a bit (apparently to find a sweet spot). I have taken the door card off and the mounting (3 screws) that holds the motor to the inside of the door has been changed at some point and was actually zip tied in place (the screws having been drilled off) So I wont be able to screw it back into place. I tried it in all manner of positions to get it to wind down and it won't move, I can feel the motor itself clicking, but it seems to be jammed. After about an hour of trying the thinner end of the moter that would be nearest the front is getting a warm. I dont think this is a major issue as it used to work fine. Could those 2 cable's have siezed? The 2 arms seem that bring the window down seem to be sat in the runners correctly etc. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted July 16, 2017 The motors end up seizing over time. Try getting hold of a 2nd hand compete mechanism and replace it. I had the same problem as you. Sent from my SM-G930F using Tapatalk Quote Share this post Link to post Share on other sites
