Aaron10
Vacuum tubing
Hi all,
Upon further investigation and advice from yourselves (due to a no boost reading on the mfa) I am in the process of ordering up the vacuum pipe (3.5mm inside diameter as recommended) to change all the vacuum lines on the car. I just had a quick look and the hose going from the ecu to throttle body at the moment is only 3mm. How would this affect the car if at all?
