Pc80 10 Posted August 14, 2017 Hi folks The indicators on my VR6 have stopped working. When i move the indicator switch, up or down, nothing at all happens. If I press the Hazard button it lights up in red and doesn't flash. The indicator lights don't come one, nor do the little arrow signals on the instrument panel. I did mess around with the underdash tray and fuse box cover (attempting to replace the grey ones with black ones), so perhaps I knocked the fuse, but I didn't notice doing so. Any thoughts? Thanks. Quote Share this post Link to post Share on other sites
Philly-R6 1 Posted August 14, 2017 You could try reseating the flasher relay - position 6 on the fusebox (I think). Also, make sure the fuses are correctly seated. Do the indicators work when the alarm is set? Quote Share this post Link to post Share on other sites
Pc80 10 Posted August 14, 2017 Just checked - all the indicators and arrows on the instrument panel do flash when I set the alarm. Does it still sound like a fuse issue? Cheers Quote Share this post Link to post Share on other sites
Philly-R6 1 Posted August 17, 2017 The alarm powers the indicators, when setting. Aye, sounds like the fuse - did you check the flasher relay was seated? Quote Share this post Link to post Share on other sites
Pc80 10 Posted August 18, 2017 Not yet. The car is difficult to get into at the moment as I have a load of stuff around it. Soon as I get chance I'll check. Does sound like a fuse though. Cheers. Quote Share this post Link to post Share on other sites
