David van Gemert
help needed with radiator problems
hello i hope someone on here can help me .
I drive a vw corrado 2.0 16 valve with an automatic gear transmission .
My car got to hot so i checked the radiator wich was leaking so i checked for a new one .
And what do i see the on that was fitted was to small for my car .
So i guess that was why it would run hot .
it says you need the bigger one if you drive with a automatic transmission or have ac on it .
Is this true ?
Does anyone know wich kind of radiator i can put in wich is a good price ?
Can i maybe swap it with a vr6 radiator from a golf cause i know someone who has one .
Is there anyone who has picture from the radiator and its housing .
any help would be appreciated .
Greetings from the netherland:cool:s
Hi David,
The radiator is indeed bigger on the a/c equipped corrados.
You would also need the longer water hoses too though, possibly off a G60 model that has the 600mm long radiator and possibly the bigger fan housing.
If you need the hoses, let me know as i have a few.
Cheers-Andrew.
