1200 bandit
Fitting coilovers
Just got some new adjustable coilovers
Do the original top mounts have to to use on the fronts (have new front top suspension mounts)
Are the rears a just a bolt on job
Only replacing because they are possible 24 years old
replace everything while you are there as unless it has been replaced recently it will be bolloxed, do not use cheap top mounts as they will knock within weeks, i found out the hard way with our fabia|| euro car part cheapies, crap.. you only gain benefits from replacing all suspension bushes when changing the shocks
