Bally 0 Posted July 22, 2004 I've noticed a knocking noise coming from front drivers side ever since I had a new CV outer boot done, its been all tracked up & is all ok.. wondering what could be causing it? also it feels like something loose as there play as I pull away like somethings not tighten enough Pls advise... Quote Share this post Link to post Share on other sites
Henny 0 Posted July 22, 2004 sounds like it could be your anti vibration damper has come adrift... :| Have a look HERE for details and photos of said damper... 8) Quote Share this post Link to post Share on other sites
Bally 0 Posted July 23, 2004 Cheers Ian, I'll get it looks at then... 8) Quote Share this post Link to post Share on other sites
G60Dan 0 Posted July 23, 2004 Also check everything is done up, just as a precaution. I had a lower arm & bottom ball joint replaced on mine, 2 weeks later it started to feel worse than b4 it was all done. I found the bottom ball joint was coming loose!! The garage couldn't have done it up very tight! Did it back up & it was like new ;) Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted July 23, 2004 Check the anti roll bar link hasn't broken. That makes a horrible cattering if it breaks and it can also rip the cv joint boot. Was the cv joint dismantled, cleaned and repacked with grease (hope so if the boot had split and vomitted its contents)? There's a chance that it wasn't put back together with the balls in their original slots, and the wearing surfaces don't match up any more. Best wishes RB Quote Share this post Link to post Share on other sites
Bally 0 Posted July 23, 2004 Cheers for the replies guys RB it was all greased up proper, only thing I can think is hat you said Dan looks like I'll have to pop car back get em to have another look! Quote Share this post Link to post Share on other sites
