_Matt_ 33 Posted February 7, 2018 Hey all, I've got 2 keys but each with a different profile. I assume the ignition was replaced at some point, how do I go about matching the doors to the ignition and then I can just cut the other key to match. I'm guessing changing the lock barrels on the doors and boot is the answer but how/who does this :) ? Cheers Matt Quote Share this post Link to post Share on other sites
markcunningham 10 Posted February 7, 2018 (edited) You have to get the lock cylinders out and if you have other handles laying around you can lay out the wafer tumblers, take the them all out of existing cylinders being carful not to lose the springs in n the holes. Take all the springs out. Once there out put one spring and one wafer in and push down on it til even with cylinder starting at the head or entry way. The put the ignition key in and see if it lines up with cylinder surface. If not try another wafer. If it looks good try it in the handle to make it doesn’t bind as you turn it. Try all positions and if you don’t get all 5 to work, 3 is good enough. Don’t put any springs back in the other 2 empty slots. I’ll take pictures of the procedure later this evening. Pretty sure Mk1,2 and 3 use the same wafers but check to make sure with your existing ones because I haven’t done one these in n a while. CPL locksmith Sent from my iPhone using Tapatalk Pro Edited February 7, 2018 by markcunningham Quote Share this post Link to post Share on other sites
_Matt_ 33 Posted February 7, 2018 Cheers Mark, sounds fiddly and I should buy some spare lock barrels to practice on. Quote Share this post Link to post Share on other sites
markcunningham 10 Posted February 7, 2018 The pictures I’ll post will shed light on the subject. If you have yard close by just go take the handles from any Mk1-2-3 Sent from my iPhone using Tapatalk Pro Quote Share this post Link to post Share on other sites
