marks2
Lots of free stuff
Ok caveats first
- I need this gone by 16-Apr.
- It's pickup only from between Reading and Maidenhead.
- Please don't ask me to post items.
- Priority will be given to the first person who wants to take everything away.
- The garden table is not included.
- I'd like a small donation (if possible) to be made to Cancer Research or a Homeless Charity.
With that out of the way all all parts you see were removed from a 92 G60.
Included are
- Carbon canister & pipework
- 68mm steel pulley
- G60 head. Lots of snapped studs. Cam and Cam pulley.
- Rear Beam
- Steering Rack + hoses
- Brake and fuel lines
- Cross member
- Scorpion DTM rear box
- top half of the G60 silencer.
- Brake servo + pipe work
- Metal coolant hoses
- Rear quater windows.
- Horns
- transmission tunnel heat shields
- G60 front roll bar
- G60 downpipe
- Various shields / engine plates
- 2x front lower arms
I'll probably be adding to the pile as I uncover more.
Edited by marks2
I could come over at weekend, I’ve got an estate and should get most in. Regards, James
Edited by vr6monkey
I can try, it’s a Golf estate, so should be able to get most in the back with seats down. I can come anytime Sat or Sun pm.
Little tip if its a mk4 estate you can take the bottom of the back seats out to give quite alot more space to fill with Corrado goodness. Plus the drivers seat will then go the whole way back. Just need a Philips to remove the covers then pull out the pins. I've had a full r32 interior and 2x18" alloys with tyres in the back that way.
I guess at the wrong type of cat for the exhaust in the top of picture one :)
Meow...
Edited by delfinis38
