paceo 10 Posted August 5, 2018 ebay link here :cheers::cheers: https://www.ebay.co.uk/itm/332748086586 Last of the parts from breaking my VR6 golf mk3 - have a read ;-) Full set of driveshaft bolts with clamps x12 - £5 vr6 flywheel - £35 vr6 auxillery belt tensioner genuine vw - £25 rare rear undertray, some models had a rear undertray - £25 pair of front bumper indicators, one tiny tab broken - £5 front suspension cups - £10 genuine hella front headlight rear RIGHT cover - £5 lovely condition front toweye - £5 transponder box and ring (needed for conversions) - £15 sunroof switch cover - £5 steering cowling, fits great, one screw in tab broke but use a longer screw and its fine - £8 fusebox - £10 relays - £5 each interior mirror - £2 battery clamp - £2 exhaust manifold heatshield - £5 new fram airfilter, its dirty from storage - £2 rare pas pump splash cover, someone has cut into it a bit - £5 water hoses - heater matrix, lower radiator and TB pipe - price per pipe - £10 front crossmember power steering metal pipe, they always rot badly, this is ok - £10 power steering bottle with green cap and pipe - £10 rear knock sensor - £5 rear middle seatbelt - £5 aircon switch - £8 single window switches - £5 each rear demister switch - £5 some dash blanks - £2 the lot genuine VW cam sensor - £20 (ridiculous money new) brake light switch - £5 uncracked exhaust manifolds - £10 front wiper motor - £5 alternator wire - £5 Vr6 front crossmember, this is only specific to the vr6 model as it has a protection bracket for the front engine mount, other mk3 models do not have this - £20 bonnet sound deadening (with clips) - £10 aircon pipes, one that goes all the way around and one that goes under the battery tray - £10 each aircon condensor bottle - £10 im located bromley in kent, i can post most parts out with a courier ;-) Quote Share this post Link to post Share on other sites
jim182 10 Posted August 19, 2018 Hi mate, you haven’t got the fuel pump loom still have you? Cheers Jim Quote Share this post Link to post Share on other sites
