paceo
loads of golf mk3 vr6 parts from breaking my vr6!
ebay link here :cheers::cheers:
https://www.ebay.co.uk/itm/332748086586
Last of the parts from breaking my VR6 golf mk3 - have a read ;-)
Full set of driveshaft bolts with clamps x12 - £5
vr6 flywheel - £35
vr6 auxillery belt tensioner genuine vw - £25
rare rear undertray, some models had a rear undertray - £25
pair of front bumper indicators, one tiny tab broken - £5
front suspension cups - £10
genuine hella front headlight rear RIGHT cover - £5
lovely condition front toweye - £5
transponder box and ring (needed for conversions) - £15
sunroof switch cover - £5
steering cowling, fits great, one screw in tab broke but use a longer screw and its fine - £8
fusebox - £10
relays - £5 each
interior mirror - £2
battery clamp - £2
exhaust manifold heatshield - £5
new fram airfilter, its dirty from storage - £2
rare pas pump splash cover, someone has cut into it a bit - £5
water hoses - heater matrix, lower radiator and TB pipe - price per pipe - £10
front crossmember power steering metal pipe, they always rot badly, this is ok - £10
power steering bottle with green cap and pipe - £10
rear knock sensor - £5
rear middle seatbelt - £5
aircon switch - £8
single window switches - £5 each
rear demister switch - £5
some dash blanks - £2 the lot
genuine VW cam sensor - £20 (ridiculous money new)
brake light switch - £5
uncracked exhaust manifolds - £10
front wiper motor - £5
alternator wire - £5
Vr6 front crossmember, this is only specific to the vr6 model as it has a protection bracket for the front engine mount, other mk3 models do not have this - £20
bonnet sound deadening (with clips) - £10
aircon pipes, one that goes all the way around and one that goes under the battery tray - £10 each
aircon condensor bottle - £10
im located bromley in kent, i can post most parts out with a courier ;-)
