dannyp01
Water leak from charger feed
Well its definately water and it looks like its coming from a nut on the head with a pipe on it, I could'nt get very good look and you know how many different pipes there are on these engines I tried to follow it best I could.
I'll have another look tomorrow when the light is better.
I'm guessing you have got a flange problem, the plastic flanges that attach to the block that then connect to the water hoses can leak, they are cheap to replace, but it means new coolant.
can be done for less than £30 yourself useing OEM parts and a bottle or two of G12+ coolant from VW depending on where you live. I always buy two bottles of coolant and mix in a large clean container with distilled water (cleaner water than tap water). I use 3 parts water 1 part G12 because i live in spain and it doesn't get to cold here
