mr.ots
Mystic Blue Corrado VR6 Storm for sale £9750.00
For sale is my 1996 Corrado VR6 Storm, which I have owned since 2005.
The car has been regularly serviced and has a full VW service record up to 100,000 miles and then serviced by myself up to its current mileage of 119,800 miles. The car comes with an extensive full documentation showing all work carried out and receipts for all parts replaced.
Work carried out includes:
Oct 2011 - Oil & filter service (112,305 miles)
Front pads replaced
Front calipers refurbished (at Big Red)
Rear discs and bearing replaced
Rear pads replaced
Replaced track control arm rear bushes (with R32 bushes)
Replaced ball joints
Replaced anti roll bar bushes
Replaced drop links
Dec 2013 - Full service (116,693 miles)
Feb 2014 - Replaced power steering fluid
Replaced Auxiliary Belt tensioner bearing
June 2013 - Replaced all brake system hard lines (with Kunifer) from ABS pump to calipers
Upgraded flexible brake hoses with Goodridge braided hoses
July 2013 - Replaced crack pipe
Replaced Water pump
July 2016 - Refurbished brake master cylinder (professionally carried out by past parts)
Replaced front discs & pads
Replaced brake pressure regulator
Mar 2019 - Removed rear beam and repainted & fitted new beam bushings
Replaced rear shock absorbers and top mounts
Repainted fuel tank straps
May 2019 - Replaced front shock absorbers and top mounts
Replaced tie rod ends
Replaced steering rack bellows
Replaced coolant thermostat
Replaced thermostat housing coolant sensors x 3
Replaced oil cooler seals
May 2019 - Carried out full service including
Oil & Filter
Air filter
Fuel filter
Spark plugs
Ignition lead set
The car has a current MOT expiring on 28/06/2020. There is 1 current advisory for a small oil leak from the oil cooler.
The engine runs superbly and pulls like a train.
All electrics on the car are in full working order, the spoiler raises at 60 mph and the sunroof both tilts and slides. The interior of the car is in superb condition with no cracks or tears to the seats or door cards. The original warning triangle and first aid kit are still present.
The exterior of the car is in very good condition with only minor defects to the bodywork as you would expect for a car of this age. There is no major rust anywhere on this car including the underside which has been waxoyled as necessary to prevent corrosion. The sills are also in excellent condition. You will however find the usual stone chips on the bonnet and front wings and minor defects.
The car also comes with the following items:
Birth certificate from the Volkswagen Museum confirming production date of 3rd May 1995 and Storm specification.
Extensive folder containing all documentation
Every MOT certificate from the first one in 1999 to present
Installation certificate for Clifford Concept 50 x car alarm and service receipt from Feb2007
17 road fund licence discs from Feb 2003 onwards
2 sets of keys with alarm fobs (all locks and ignition use same key)
An additional set of BBS solitude wheels (require refurbishment).
Hankook Evo V12 tyres all round with 6.5mm tread depth on the front and 7mm rears
There are a couple of issues with the car at present which are the ABS light will sometimes stay on for a while after a cold start but goes off after driving for a while and the head lining is sagging and needs to be replaced.
If you are looking for a totally standard, unmolested Corrado VR6 Storm then this is the car. I currently have an agreed insurance valuation from Admiral of £12,000.
Please note, the personal registration is not included in the sale and will be removed prior to sale.
The car is located in Addlestone, Surrey.
Please PM me with any questions.
Photos & video here:
https://photos.app.goo.gl/ELoEVt1kHXaSHcYz5
Edited by mr.ots
