Motoriousss
Corrado VR6 Storm Opinions
Hi all
I'm looking at this Mystic Blue VR6 Storm on facebook marketplace.
https://www.facebook.com/marketplace/item/389717998400288/
Both rear sills are corroded but not excessive according to the last MOT
The listing is as follows:
  • 3 former keepers last owner for 13 years registered 05/01/1996 mot due Jan 2021
  • 190,000 fully rebuilt engine with only 29k since rebuild engine rebuilt in may 2013 by stealth at 161,000
  • comes with full service history including vw, stacks of paper work receipts invoices for all work carried out no expense spared
  • chains done by d&g autotech using genuine parts and stronger mk4 parts (receipt to prove) in 2010
  • 263 cams fitted with dave dewson remap in 2010
  • vibra-technics engine mounts front rear and gearbox fast road
  • jetex cat back exhaust
  • gearbox stripped and rebuilt
  • wavetrac limited slip differential fitted
  • slim line fans fitted – these make a massive difference with regard to cooling
  • cv joints and track road ends replaced in 2010
  • rear axle bushes replaced 2013
  • alternator replaced in 2013
  • maf replaced 2014
  • new vw fuel pump in 2013
  • new vw starter motor in 2012
  • black leather in good condition slight rip on drivers side
  • original re-leathered steering wheel with the red stitching
  • car will come with both winter rubber mats and summer carpet mats for interior
  • heater matrix replaced in 2013
  • 16” spare wheel from late golf vr6 so spare goes over bigger front brakes
  • clifford virtual key immobiliser installed comes with new style keys & fobs
  • alpine head unit 117ri with usb connector in bottom shelf, original audioscape front door pods
  • bodywork needs attention needs some tlc, rust scab on drivers door and passenger door, small area of lacquer peel on bonnet, chips on rear bumper
  • underneath waxoyled in 2015 since then the rear sills had corroded and were noticed during mot so these have been repaired and needs respray in that area
  • vw lupo aero wipers and arms fitted
  • replacement wiper motor arms and motor fitted in 2014
  • headlights new glass
  • up rated headlight loom installed
  • trim sport carbon fibre rear number plate light trim
  • rear number plate plinth broken in places
  • spoiler motor replaced and is now fully works as it should up down on the button and rises at 57 mph
  • DDI blue tinted wing mirrors
  • new windscreen fitted in 2013 upgraded front brakes to 288mm refurbished by biggred and upgraded lines
  • mk4 golf rear brake calipers
  • kw v1 coilover suspension fitted comes with tool to adjust
  • new rear discs/pads/abs rings and bearings in 2017
  • solid brakes lines fully replaced everyone brand new copper when replaced in 2013
  • abs rear brake load compensator replaced 2013
the list price is £6,100 and I want to know what to look out for on the undercarriage of the car. I am well aware of the damage on the body of the car. But in terms of important parts that have rust, I am not sure.
Thank you!
