.A.N.T. 0 Posted August 2, 2004 Should just be a simple yes/no answer... In the life of the Corrado, have there been any changes to the wings?? Would a 94 wing fit to a 91 Corrado??? Cheers!! Quote Share this post Link to post Share on other sites
Andy Brookes 0 Posted August 2, 2004 yes they have changed will fit but is very slightly wider Quote Share this post Link to post Share on other sites
Henny 0 Posted August 2, 2004 change was around '92, the same time the bonnet changed from being an inny ---___--- to an outy ___---___ (Look at the front edge of the bonnet and you'll see that the center section either dips in, or lifts up from the outer edges and the two pics above will make sense... ;) ) As Andy says, the wing will physically fit, but unless you put both on, it'll look odd if you've one of each on as they are slighly different widths... :| Quote Share this post Link to post Share on other sites
gibber 0 Posted August 3, 2004 Wot is the actual width differance? does any one know? Is the arch profile still the same? Quote Share this post Link to post Share on other sites
Skimask 0 Posted August 7, 2004 Aint sure about sizes, but I bought a new wing for my 91 corrado, and the dealer checked my VIN number for an 'L' in it. I gather if the VIN has an L then its the earlier model, don't know about later ones though, should,ve asked!!! Quote Share this post Link to post Share on other sites
