JonnyHull
2 x VR6 Right rear engine mounts
For sale are 2 right rear engine mounts for a VR6 Corrado. One is a brand new Mapco (Part number 36839) part and the other is a Metzger (Part number 8050818) that had been fitted to my VR for the last 2 years (less than 3000 miles covered during that time).
2 years ago I had the engine out for timing chain, tensioners and head refurb at Stealth and at the same time replaced all the engine mounts. As OEM ones are longer available from VW I fitted the Metzger right rear mount along with Febi front and gearbox mounts. I’ve never been happy with the NVH at idle since the work was done and Vince suggested I buy a couple of other brands and he’d swap them out and check each one in the workshop.
I ended up with a Quinton Hazell rear mount and it completely cured the idle vibration I’d had before.
I suggest anyone replacing mounts these days does the same and has a few options of each at hand as they all vary. Vince said the same thing, it’s a bit of a lottery with the aftermarket parts and one setup on one car might not work on another.
Happy to sell individually but suggest these a both trialled to get the one that provides best setup for your car.
The Mapco part is currently available on Autodoc for around £39 and the Metzger part for around £50.
£60 for the pair delivered.
