CHRISVR6 0 Posted August 10, 2004 This has probably been done before but just wanted to know if there is anything important with these, i am changing the drivers side as the three wires have not been conected when the previous owner changed the handle over (diff key as well), i have pretty much had it out anyway but can the locks be changed i.e. passenger side one fit drivers side (lock only not handle), cheers Quote Share this post Link to post Share on other sites
Henny 0 Posted August 10, 2004 yes, the barrels are identical. make sure you have the correct key in the ones you want to keep as you remove the barrel though else it may fire the pins out as you remove it from the handle! :? Quote Share this post Link to post Share on other sites
