devnull 0 Posted August 12, 2004 I just finished rebuilding my VR6 from the ground up -- I took it to the machine shop for cleanup, had it balanced, bought all new seals, etc. etc. However, since I've gotten it all going, it gives off a little bit of smoke from the rear passenger side of the motor. Is this normal? It doesn't seem to be overheating (though I only drove it around a few blocks to test it out), and I don't have any parts that I forgot about... I am guessing that it will just do that for a little bit as everything settles and fills in gaps, etc. But, I thought maybe someone here would have some suggestions. Thanks! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 12, 2004 Oil spillage?? - probably just needs to be burned off Quote Share this post Link to post Share on other sites
