Heardy
Personal steering wheel on snap off boss
How do i get a personal steering wheel to fit on a raid snap off boss? The holes are alligned correctly but the screw holes are the wrong diameter,also even if i mannage to bolt it together the horn push won't fit properly.
Is there an adaptor i need?
Sounds like you need an adaptor ring - although I'm not sure one exists to help you get round the problem, as most of the adaptor rings are for getting the correct hole alighnment rather than diameter of holes? Still worth trying. I needed a adaptor to fit my Italvolanti to the Raid - Motech do them. You might also want to try a Personnal agent as they may have come across this issue before.
The only other thing I found was that the raid snap off boss spaces the wheel a fair bit closer to you when your sat in your seat. I had to use a different (shorter) wheel boss to compensate for the thickness of the Raid.
