ollyb
idle
1.8 engine and idle seams to be low, also hunts alot between 700 and 2000rpm on idle. Other than the idle control valve on top of the head what else can cause this?
Your basic idle settings might need resetting.
Or could mixture - should be 2%, if your having problems starting then probably that.
Try cleaning it with carb cleaner, otherwise -
18225 .. IDLE CONTROL VALVE CO 1.8 16V 4/89 >7/91.. 89.00 + VAT
If you need one :wink:
Check to see that you have the knock sensor/ idle stabilizer valve plug on the back of the throttle body plugged in, I had the same problem till I plugged that in, then I realized that the boost build rate sucks and then unplugged it again so that my car wouldnt be so slow off the line.
