Heardy
Front Suspension Top cup part number?
I've just fitted some eibach sring's to my 93 VR6 and the top cup's seem to small.
The part number's are 357412 341A are these correct for eibach spring's or are there some larger one's? any help would be appreciated
Cheers Jason
So far as I'm aware there is only 1 type of top spring plate for the VR6 - I even have them fitted to my G60 8)
The front springs should taper inwards at the top to meet the spring plates.
Thank's for the link Andy :)
ok just to update this so everyone knows the score...
aparently the change was in 1994 on the corrado front suspension and most spring suppliers only provide for the pre 1994 cars.
part number for the larger spring plate is 1H0 412 341 and is about £10
The part number on mine is 357 412 341A does this mean mine already has the larger spring plate's on even though it's a 93 model.
I have a 94 VR6 and had to change the spring plate for the larger size 1H0 412 341.
If you have 357 412 341A Then you have the smaller plate size.
If your spring plate doesn't look right then I suggest you change it for the larger type, otherwise the spring at the very least will damage the plate.
the A in the part number does make a difference, you need to get the correct spring plate or else the spring will work its way off and you'll have all kinds of problems!
Cheers !!
Looks like i'll have to strip it back down again then :cry:
I just hope it will last a couple more trips to the girlfriend's in manchester before i get chance to sort it out :wink:
