biggrim
Removing fog lights
I have a 92 G60 (early type) and need to know how to get the foglights out. I have removed the indicators and the two screws that hold the foglight in place. Does the fog just pull out or is there a knack to it? Probably really simple but it's the first thing I've tried to do to my C in the three months I've had it. Thanks in advance, biggrim
Should just pull out once the screws are removed. Try levering one side out first with a flat head screwdriver.
Once you undo the screws, pull it towards you and awy from the number plate, there is a litlr plastic 'pin' that fits into the bumper.
HTH
