JBOB
Seatbelts
My car has no rear seat belts, someone must have taken them out in the past, so i bought some of a guy down the road from me, he said that they were tested and they were cheap so i brought them home.
The problem is that they have curled up as they should and wont uncurl no matter what i do with them, ive never really worked with seatbelts before.
can any one help.
Cheers J
you need to orientate the mechanism to pretty much exactly how it would be in the car else it'll lock up. Were the seatbelts originally out of a Corrado? if they weren't you may have problems trying to get 'em to fit... :|
they have to be on the axis they would be in the car mounting points or they will lock up due to a ball bearing level/inertia device .........but whatever you do dont try and remove the side covers as the spring will more than likely fly out and they are a complete sod to put back in :lol: :lol:
edit: henny beat me to that one :roll:
Im away this weekend, so i will try that on monday,ill let you know how i get on.
And yes the belts are out of a Corrado so they should fit.
Oops Just took off the side of the seat belt and the spring came out :oops: (Before i read this post)
Err any suggestions
Are they the same as mrk golfs/jetta/passats?
BEavisjem
