aposegil 0 Posted September 29, 2004 Hello guys I really really need someones help out there Ok a bit of back ground to help out My car has started of as a 1.8 16v on k-jet and I got hold of a complete loom from a corrado G60 with no wires cut. So i removed the four or five plugs (cant remember how many) and replaced them from the g60 one. Straight fit no problems. Anyway ive just finished all the work need and gone to start it and everything is turning fine but the flipping pumps arent getting power :mad: fuel relays are clicking fuel pump fuse is fine and corret one the only thing i cant find is the fuel pump over-run so come on guys please tell me what whats going wrong?? and i have connected something wrong??? Quote Share this post Link to post Share on other sites
Joe M 0 Posted September 29, 2004 Could it be something to do with the 16v running 2 pumps but the g60 only runs a single, in tank, pump? Quote Share this post Link to post Share on other sites
aposegil 0 Posted September 29, 2004 thats whats going through my head at the mo :( its really winding me up :cry: Quote Share this post Link to post Share on other sites
W3RKD 0 Posted September 29, 2004 is the pump priming alex ? Quote Share this post Link to post Share on other sites
aposegil 0 Posted September 29, 2004 whats priming? all i get is the from the back when i turn it off but no vibration or anything from the pumps ive taken the connection off and no power at the pumps Quote Share this post Link to post Share on other sites
Jim 2 Posted September 29, 2004 Priming as in when you turn the ignition but don't actually start the car, you should hear the fuel system repressurize itself - ie a second or so of whirring from the fuel pump. Quote Share this post Link to post Share on other sites
aposegil 0 Posted September 29, 2004 yeah its not doing that also ive just been investigating a little futher using the good old bentley's manual and i dont know if its me but the fuel pump relay is clicking but on the "exit" side there is no current showing I opened it up and it looks fine but can see it moving do these relays go often?? Quote Share this post Link to post Share on other sites
Joe M 0 Posted September 29, 2004 They do sometimes, have you tried bridging the connections to see if the pump comes on? Quote Share this post Link to post Share on other sites
aposegil 0 Posted September 29, 2004 can u do that? got a piece of wire was going to stick it inbetwwn the terminals but didnt want to incase i damage the fuse box :oops: Quote Share this post Link to post Share on other sites
Joe M 0 Posted September 29, 2004 Yeah, just stick a bit of wire between the 2 thicker pins and plug it back in. Quote Share this post Link to post Share on other sites
aposegil 0 Posted September 29, 2004 what the relay?? i would have thought just putting the two wires in would be fine? Quote Share this post Link to post Share on other sites
Joe M 0 Posted September 29, 2004 Should be, I had to run my car like that though so didn't want the wire to fall back out. Quote Share this post Link to post Share on other sites
aposegil 0 Posted September 29, 2004 oh ok cool give me five mins going to go and try it now :) Quote Share this post Link to post Share on other sites
aposegil 0 Posted September 29, 2004 JOE I COULD KISSS U!!!!!!!!! FUEL PUMP JUST CAME ON :D :D :D :D :D :D :D :D :D :D :D :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: sorry for the shouting but tomorrow going to run out and get a relay so i can start it :D p.s Joe dont worry im not going to kiss u lol :roll: :shock: :lol: Quote Share this post Link to post Share on other sites
Joe M 0 Posted September 29, 2004 :lol: glad to be of help. Quote Share this post Link to post Share on other sites
Rossco 0 Posted September 29, 2004 Could it be something to do with the 16v running 2 pumps but the g60 only runs a single, in tank, pump? Is this true? i though all rads used the 2 pump set-up, please enlighten me Quote Share this post Link to post Share on other sites
Joe M 0 Posted September 29, 2004 afaik only the 16v models run the 2 pump setup. Its more powerful than the vr/g60 setup as the K-Jet system requires a higher fuel pressure from what ive read. Quote Share this post Link to post Share on other sites
h100vw 0 Posted September 30, 2004 Alex, the fuel pump should only run when the engine is rotating, except for when it primes. This is a safety feature to prevent fuel pumping all over when the car has been involved in a prang. The fuel pressure for a G60/VR is lower than that of a 16v. The difference due to the the fact it is the fuel pressure that opens the injectors on K-jet. A K-jet engine would run on a digifant pump but the low fuel pressure would cause problems at high revs due to inadequate fuel delivery. Gavin Quote Share this post Link to post Share on other sites
aposegil 0 Posted September 30, 2004 yep pump was priming but becuase i didnt put in the clips on the injectors.fuel rail to hold it all in together it started to leak out of there :( but going to see if i can get it started tonight Quote Share this post Link to post Share on other sites
Rossco 0 Posted September 30, 2004 afaik only the 16v models run the 2 pump setup. Its more powerful than the vr/g60 setup as the K-Jet system requires a higher fuel pressure from what ive read. Im just about to embark on this conversion myself over winter, got everything together just gathering info at the mo so it all goes smoothly, will i be able to leave both pumps on the car or will i nee some G60 fuel lines to remove the undercar all together? Quote Share this post Link to post Share on other sites
Joe M 0 Posted September 30, 2004 Harry, The g60 should run fine with the 16v fuel pumps, in fact, the pump would probably be capable of going to a higher bhp rating than the g60 one. The connection on the fuel hose is different however. The 16v uses a sort of solid line with a banjo fitting on the end, the g60 uses standard fuel hose with a clip. This would need to be adapted somehow and the clips would have to be pretty decent to withstand the extra pressure. The extra pressure shouldnt be a problem with running as the fpr will compensate. aposegil, thinking a bit more on your problem, the above test only really shows the wiring is ok between the fuel pump and fuse box. We still dont know if its definately the relay thats the problem or if its not being activated. Try putting a multimeter or test light in where the 2 thinner pins on the relay go and turn the ignition on and see what happens. Should get a voltage for about 2 seconds then drop back to zero, then a voltage when turning the engine over. Quote Share this post Link to post Share on other sites
aposegil 0 Posted September 30, 2004 well as ull prob see as ive just posted up on the general forum it wasnt the petrol pump relay I alos found that there was no spark which upto that point i didnt think about checking it was actually the fact i had no ECU relay it was only after alot of headache did we realise this as the 16v never come with them standard :roll: but the min i "borrowed" one of migs the car electronics worked :D Quote Share this post Link to post Share on other sites
Joe M 0 Posted September 30, 2004 Cool, so its running now? Quote Share this post Link to post Share on other sites
aposegil 0 Posted September 30, 2004 yep woke up a neighbour of mine when it started up lol also feck me its loud when it dumps air lol Quote Share this post Link to post Share on other sites
