capnahab
Corrado's Leaking
Hi all. I puchased my C about 3 weeks ago now. After the foul weather recently i noticed the windows steam up when its outside my house. This isnt a good sign, so i go and check the carpets. sure enough, the front and back ones are wet. The car is not parked at an angle.
Are there anyt common corrado problems that wil lead to interior leakage?
Also, the underneath was Waxoyled by the previous owner, would this have anything to do with it, like blocking drainage holes at all?
Previous owner probably wouldnt have noticed leakage as its been kept garaged.
Cheers for any help!
Firstly check that there arent any leaves and other debris under the front scuttle cover (where the wiper motor is), if the drainage holes are blocked the water will be entering the car.
