VEEDUBBED
ABS Light+Rev counter....
Evening all,I need some advice on a few problems regarding the ABS warning Light on the Dash,it stays on and does not go out like it used to.This happend after I converted my G60 to run with a different Injection sistem;Weber/IAW.My Car runs ok,it has no Digifant components at all,the entire Wiring harness exept for the two main Earths are taped up.What I don't understand is how is the Digi G60 ECU is connected with the Abs?,the ABS ECU is still attached as is all wiring.Also I can't get my Rev counter to work either,I'm still using the original G60 Ignition Coil and I've tried to connect the Weber's Rpm Feed to the coil's green Wire,no joy.HELP me here PLEASE,the ABS I can do with out but on a Twin Cam 16VT the Rev counter I need.Ciao. PS,On my last Car-Golf 2 1800 16VT-the Rev counter worked fine when I connected the Weber's Grey/Black Rev counter Feed to +15 on coil....?
