Coley17778
HELP NEEDED
The car starts fine but when its cold idle revs up and down this cures itself after 1 or 2 miles.Then totally at random the car will overrun when changing gear and the car will idle at 1500to2000 rpm this could just cure itself at next junction cannot get a ride out in this car without these symptoms happening cannot get my mfa reading above 21mpg no matter how steady i drive could this be linked have replaced isv,temp sensor but to no sucsess any ideas cheers
STALLED CAR GOING INTO CAR WASH AND WHEN I STARTED UP REVS STUCK AT 2500 BLIP ON THROTTLE SOLVED THIS DOES THIS SHED ANY LIGHT NEEDING IDEAS GOT MONEY TO FIX BUT DONT WANT TO GET RIPPED OFF
I get the same since fitting a new lysholm charger but I was putting this down to it needing a tune for the extra boost. I have lately been thinking that something else is not right.
