quikstu 0 Posted February 22, 2005 Got a 1994 VR6. Boot lock has seized & will not open. Thought it was just frozen after washing it but thats been two weeks now!!! Not exactly easy to get at the lock from within the boot. Anyone had this problem? Ideas/remedies???????? Thanks in advance folks. :( Quote Share this post Link to post Share on other sites
h100vw 0 Posted February 22, 2005 What exactly do you mean mate? Is the central locking not unlocking it or is it that the key doesn't work in the lock but it does release the boot? As most folk have alarms that work the locking remotely, it would only be a concern that the key doesn't operate the lock if you have fitted rear handles. Gavin Quote Share this post Link to post Share on other sites
atif 0 Posted February 22, 2005 Mate, i had the same problem last time! i got some spray grease and stuck it in via the little straw and sprayed it in. left it for 15 mins and it suddenly let me open it! Also it was much easier to open after that! Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted February 22, 2005 ive had this problem. mine needs a new lock but from the inside take the panel off and have a look at the locking plunger and see whats what. after that its bot lock time Quote Share this post Link to post Share on other sites
quikstu 0 Posted February 22, 2005 Gavin, I dont have remote locking, just the old fashioned 'key in the lock' thang! The central locking works fine for the doors & I can hear it coming from the boot although it doesn't release. Already tried "atif's" method to no avail! Although will try again. Will go for the contortionist way & take the cover off. Thanks guys, MUCH appreciated. :) Quote Share this post Link to post Share on other sites
ryan 0 Posted February 22, 2005 Hmm this is interesting..... This sounds really stupid but I didn’t realise that the boot formed part of the central locking on the C. I don’t have remote – only the key in the lock jobbie. :oops: My boot opens with the key but only if you use the lock on the boot itself, none of the doors have an affect, and the lock on the boot has no affect on the doors. :roll: Also, the boot locks as soon as it is shut, so its possible to lock your keys in it !!! :shocked!: Go on – tell me – is this wrong - It’s a M-plate 8valver. Sorry to steal your thread quikstu – it wont happen again ! :thumb right: Quote Share this post Link to post Share on other sites
h100vw 0 Posted February 22, 2005 quikstu said: Gavin, I dont have remote locking, just the old fashioned 'key in the lock' thang! The central locking works fine for the doors & I can hear it coming from the boot although it doesn't release. Already tried "atif's" method to no avail! Although will try again. Will go for the contortionist way & take the cover off. Thanks guys, MUCH appreciated. :) Have a read of the owners manual. You need to set the lock in the correct position to have it work of the central locking. I can't remember if the lock needs to be vertical or horizontal. Anyway, it sounds like yours is in the wrong position. If the lock is seized up then you'll need to have it all in bits to free it off. That'll probably involve having the inside off the hatch and maybe the number plate panel too. Gavin Quote Share this post Link to post Share on other sites
DaveStorm 0 Posted February 22, 2005 Quote Have a read of the owners manual. You need to set the lock in the correct position to have it work of the central locking. I can't remember if the lock needs to be vertical or horizontal. Anyway, it sounds like yours is in the wrong positio Lock needs to be in the horizontal position for central locking to operate boot. If it's in the vertical position it is always locked, until you unlock it manually! :wink: Quote Share this post Link to post Share on other sites
quikstu 0 Posted February 23, 2005 ryan said: Sorry to steal your thread quikstu – it wont happen again ! :thumb right: Not a problem buddy. :) Gav, always have the boot lock horizontal. But boot not opening with the key either!!!!! :evil: Quote Share this post Link to post Share on other sites
