biggrim
Kinky Pipe
Hello there!
I've got a 92 G60 and I've fitted a boost return kit. Now, this pipe bit has a bit of a kink in it. Is there a special way to route this to get the kink out or is it just the way it is?
Sorry about the guff quality pic, was on the phone camera. Any suggestions are welcome. Cheers
I put mine over the top of the boost pipe. Then i cut the pipe so that my catch tank is just after the boost pipe, ill see if ive got any piccies..................................................................................................yep check here
top right hand corner loon
What did you do to the boost return hose from the bottom of the throttle body to the back of the charger? Usually this tube is left in place and the breather from the valve cover is still routed to it and the ISV is rerouted from the bypass tube to the intake hose on the boost feed tube.
Cheers, Dennis
The one that came with the kit matey. I'm getting a catchtank made up just now so currently goes into an oasis bottle. Had tried putting it over but it just kinked the other way. Hmmmmmm If you can get some piccies up that'd be great. Cheers for yours Ross. You need to give that alternator a clean mate!!! ;)
Just got a new alternator loon, its mint 8)
