the_croft
dump valve on G60
Hi all, i have a mate who has a g60 and he swears that you can get a dump valve fitted, i have looked all over the internet and can only find valves for turbo's.
any help would be great.
Yes i believe it can be done but your much better off doin the "boost return mod" which is 1. cheaper and 2. should actually increase power (unlike dumpvalves!)
A dump valve on a G60 sounds like a wet fart, due to it dumping oil as well as boost. Give G-man a PM and ask for a boost return kit.
It's mainly to stop turbulance in the charger, but you get a good "woooosh" noise with it too!!!
You certainly don't need a dump valve unless your running specific turbos at very high boost (T4 - 30psi)- nearly all standard turbos actually run with less lagg without the dumpvalve....
Been asked and answered (in depth) before.
Use the search Luke.
