rayb74
Help 2.0 16v
Ok before I get stuck in can you help me with these Easy questions?
Can I jack up under this?
What size A/F are these Meant to be?
And can anyone point out on here where abouts I can attach an engine lift or where I can strap so I can lift the front of the car ? (The rear is up on ramps)
Right,
attach your sling/chain to the
lifting hook located(should be) above the alt.braket
on the cyl. head then either rap it around the exhaust mani.
or directly to the gearbox mount braket.
There are no AF nuts on a corrado,those
exhaust clamp nuts are compleatly rusted on,go get
oxy torch...
Yes,you can jack the front up from that
position,use a block of wood to spread the engine/gearbox
weight and keep an eye on the engine's mount,
once while i was jakin up my G60 with a hyd. engine
mount,it came right out,spraying smelly hyd. oil
all over the back of the engine!.
