ashvdub
Help needed, fitting late door cards.
Hi, how do i fit later door cards (the ones with the mirror control on the handle) in replacement for early ones?
The connectors and number of wires are different for mirrors and windows.
ash
Bugger, my bad! That is for the mirrors! DOH. Could it be changed to mirrors in the title please? Sorry for the mix up. I've not got round to sorting the windows yet. Cheers and sorry again
I have a 93 later style rhs door loom if thats any good to you £12 posted.i have put later style window & mirror switches on my 90 car,thinking back im sure the later switch wire colours were nearly the same colours as the early ones,so i just matched them up,but if you using early wires to late switch the mirror controls work arse backwards(meaning left & right switches are ok,but up is down is up & tilting left is right,but hey how often do you use the mirror switches)
i am also using a later sunny/interior light switch whichs is easy to set up
