woody
Knocking Noise
Started getting a knocking, cracking noise when on full lock. Does this sound like CV Joints? Also should you change the outer cv joint as well as the inner at the same time.
Yes, CV joints would defo be suspect for those symptoms. Haven't done the job myself so that's all I can say for now.
Skye
Wouldnt bother doing the inner joints very rarely go wrong and will cost a lot to replace when then dont need doing. Plus outter cv you can do in 30 mins. :D and is far easier than the inners
I have heard from someone that the CV joints for the a 91 C are the same as the 16V Mk2 Golf. Does anybody know wheher this is true?
