kasman21
pulling to the left
Hey peeps
hope you can assist, my rado pulls badly to the left if i brake strongly, bit scary to be honest!!!!any ideas what i shud check or change??
Anything would be great?!!
Thanks guys
Could be something wrong with the right hand brake caliper, seized maybe, or maybe its just the wheel alignment. I guess you could do some heavy braking and see if the left wheel is hotter than the right one, indicating a fault with the right brake somewhere.
1. CHEAPEST test to do first is (as Steve says) the Tyre Pressures. 8)
2. Balancing (although you get judder normally)
3. View your shocks for leaking oil
4. Check brake calipers are not sticking on; jak up and spin wheel freely (within reason; you know)
5. Buckled wheel
6. Alignments - test all
(or you're breaking on a badly cambered road :lol:)
