ZippyVR6
Sanding LEDs???
As above. Just fitted the kit of Ebay for Blue LEDs on the dials. Seems ok under a towel (not dark yet) but looks like there could be blue glare on the back of the dials.
Search brings up loads about this I know as have trawled through a load but what I really want to know is can you rough up the surface of the led to help difuse the light? or will it kill the bulb?
yeah you can...if you look carefully you will see the diode? inside...so sand as far as yo like without hitting that...i find if you square of the end it difuses it a bit
