veeDuB_Rado
Battery Acid
Ok, si it was suggested I top up my battery acid becaus emy battery keeps going flat :roll: , and I got some stuff here for it:
How do I do it?
How much to put in?
How do I know enough is enough?
Fank yoo :geek:
How do I do it?
How much to put in?
Fank yoo :geek:
Most batteries are sealed for life these days???
All you need on one you can top up is enough distilled water to cover the tops of the plates inside.
Yeah, you can still fix most of them tho as they have the round things to undo, also make sure these are vented with small holes so you don't boil them whilst charging if you have overtopped it slighly...
If one chamber is low on fluid then have a go but batteries are cheap now so a new one is a good investment providing you have ruled out the car draining it?
No idea what is draining it actually.
How do I know how much to put in though? There's 6 thingys I can unscrew at the top...
Meh, If it don't work hopefully I might have some dollars left after the car gets fixed tmoz so I can get a new one..
Id look more into why your batery keep draining as aposed to filling your current one up, otherwise the problem might carry on.
Generally the fluid levels dropping in a battery is a sign of over-charging, where the fluid is literally boiled away. If this hasn't happened as a result of charging on the bench then you may find your alternator regulation is at fault.
.............or the acid is leaving the battery via the breather when you throw it round corners..............
I filled it up to the right level I think yesterday and I really had trouble with it this morning.
Car's being fixed in the garage at the moment and I've asked the bloke if he can see if I need a new battery or not.
Thanks for the help guys :)
