Talc
miracle dry car wash
err... I tried it :oops: well, something similar but probably the same stuff. Some sort of emulsifer spray that 'lifts' the dirt off the paint and leaves protective layer that ionises future dirt away so you don't have to clean it so often - Great!
Well not quite. It did seem to shift the dirt quite easily (including bird poo) but left smeary swirls behind like you had butter on the cloth. Hense "the warmer it is the quicker it takes" as you have to keep rubbing until its gone. The end result was nothing special and it certainly didn't keep it clean any longer.
If you're not that bothered with cleaning cars and want a quick way spruce up, then I spose it may be of use. But for the average C luvver, best stick with your sheepskin mit and a bucket for finest Thames Valley water.
same thing as i speed detailer i bet... if used often enough without getting mud on the car it does save a few washes though
