PoorMansPorsche 0 Posted May 1, 2006 alright peeps just trying to get the other halfs door trims off the MK4 = removed the 3 T15 screws from the bottom and still solid as a rock - does something need prising off first ala Corrado grab handle ??? cheers Brett Quote Share this post Link to post Share on other sites
Jim 1 Posted May 1, 2006 You can pull the small insert out behind the grab handle on the door.. I believe there might be a screw you can access and then pull up the whole grab handle - its sort of snapped in with about 4 or 5 clips.. get that out of the way and you will see there are about 3 big cross headed screws holding the door card on. I also think there are a few small cross headed screws dotted around the flat edges of the door.. that should be the lot! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 1, 2006 I think there were 5 screws in all when we did my mates window reg and you have to also remove the armrest bit and unplug the electrics... I also remember we had to lower the window for some reason too (told us to in haynes manual) Quote Share this post Link to post Share on other sites
funky 0 Posted May 1, 2006 you have to yank it like hell with all the screws removed most of the retaining clips will break and you will need new ones only pence from vw funk Quote Share this post Link to post Share on other sites
