Andy665
Eaton M62....
....been offered a used example with all pipework to allow a straight swap for the G-Lader - is it worth considering, I could have it for £200
No andy noware enough boost m8. That was why john got rid of his john cooper one which he was going to fit to the westfield
Woody
M62's are perfect for the g60 engine. woody,you are thinking of the M45 as fitted to minis.
The main issue with mounting the M62 as nobody does a bolt on kit for them as quite a few engine bay components need re-arranging to get them to fit nicley.
I'd normally say no and stick with the G-lader as they are reliable as long as they are looked after... but, seeing as you have 2 G60's Andy, i'd be tempted to try it out and if you don't like it i'm sure you'd recoup the £200 fairly easily...
