ed
fitting porsche wheels on a 16v rado
hi im new round here and im trying to put some 16" 928s on my 1.8 16v.
they are 16x7 for the front with an et of 65
and 16x8 for the rear with an et of 52
will the et of these be ok to fit on my car with adapters????
if so, im trying to work out what width adapters im going to need to make sure there is no scrubbage on the suspension, and i also would like them to be slightly spaced to arch if possible. i will be lowering it 40mm afterwards....
im guessing i need 30mm thickness? g&s do fk automotive ones for £214 for 4...
any help is much appreciated thanks :D
I have 17" POrsche Cup 3's on mine that are 7.5" Wide and an offset of et52. I use 25mm Hub adapters and they Fill the arches perfectly!
