flusted
G60 RUNNING SUPER LEAN!!!!
Ive just wired up a air/fuel gauge into my rado. My 1st intentions was it was running super rich as it bogs,pops and farts.
I checked the gauge today and its the oppisite! Idle it shows ok,but soon as i floor it it goes off the gauge to lean :shock:
I tried adjusting the co pot but no joy.
I taped the full throttle switch shut and adjusted the co pot to 250 and flys.
Undo the tape,and its slow :cry:
With the switch taped,when i floor it,the gauge mometerally hits lean for a split second,then hits just in rich,but its rich on idle.
Tried tweaking the co pot with switch taped but the gauge doesnt change?
What can cause the lean accelaration?
I have new lambda
New earth strap from battery to head showing 0 resistance
Same strap extended to lambda bracket
Tried another ecu
checked i have resistance on both throttle micro switches when switched
Im lost now and am completly stumped :mad:
Any more suggestions?
What AFR is it running on A, idle B, part throttle C, WOT
When the switch ISNT taped, it idles in stoich but part throttle is lean, WOT is off the gauge lean.
I am using a cheap gauge though which i presume wont be very accurate,but its a start
ecu pipe has been replaced.When ecu pipe is removed with engine running,it idles alot better,but soon as you put pipe back on,it goes lumpy?
It was doing it before i modded it.
Might buy new genuine lambda and replace the wiring up to ecu as i got lots of interferance on my gauge
