Andy T
droning noise when braking
Finally got around to fitting my new OE front discs and Pagid Fast Road Pads.
Well what a difference, not even bedded in yet and they feel so much better than the old drilled discs, lots of bite and a really solid pedal feel. Nice, the vibration has gone away too.
Looking at the old drilled discs, they were like swiss cheese, something like 40-50% of the disc surface is drilled!
'Proper' discs(e.g. Porsche) have quite small drillings, and only a small number of holes, so most of the contact area is retained.
Whovever came up with the swiss cheese discs needs shooting!
  Quote
Yeah, I keep seeing them at shows and they look pap! - its not just the contact area either, Its also the cubic area of the disc being less affecting its ability to withstand the heat generated while braking. :roll:
Exactly, hence why they crack under extreme use. Its a bit like running really small brakes, 215mm instead of 280's!
Do you know who makes them? I couldnt find a logo on them at all....
