dom
engine
engine mounts has any one changed there engine mounts just found out the car i just bought as not got long on engine mounts before it drops out what will it cost :(
engine mounts what engine mounts have you got in why will your engine drop out what kind of engine is in your corrado
cool thanks any idea on cost spent most of money buying it got a mk2 golf gti that turned into money pit :(
Just done the rear one on my G60.
The worst part was actually separating the Lamda bracket from the mount. I ended drilling the old nut out due to corrosion.
O/S front on an axle stand. Slackend the two big bolts underneath first. Remove air box for better access.
Using trolley jack, carefully lift engine to take weight off the mount (I lifted the engine on the rear engine mount bracket).
Whip out old one, slide in new one, fit bolts, remove jack & do it all up nice & tight.
Feels very tight now...!
