Rcole
Sparkless
Hi
Someone recommended the forum as you guys know your stuff.
Can anyone help, Ive had my valver for a couple of months and its suddenly died. (1993 2.0 16v)
Ive replaced the dizzy cap rotor atm leads and plusg, Ive tested the feed to the dizzy and thats fine, but its still not firing up??? Its trying but the spark just isnt there.
Can you recommend what else I can test or any ideas what the problem is???
Thanks in advance for any help
Rob
Probably the hall sender inside the dizzy. It can be replaced, or you can buy a new dizzy.
Where are you? someone might be able to lend you one so you can test that it is the problem.
Im in North Wales,
Is it worth getting one second hand? Or arnt they that much new?
Is there any way of testing it brfore buying one?
Cheers for the help
To be honest, a second hand one *could* pack up again pretty soon. Your original one has lasted 13 years.... I'd try a new one, or putting a new hall sender in it.
Search for hall AND sender for more information
remember to put the AND in (in capitals too)
Ok now I am stuck !!!
Ive replaced everything, new leads plugs dizzy cap distributor hall sender.
There is feed going in through the sensor stuck to the dizzy and through the centre lead theres fuel getting to the plugs but she still isnt sparking.
What is wrong :?
Anyone ..............
Check the plug and the three wires running to the distributor. check the coil too, that could have broken down. I suppose it could be the immobiliser, if that's hooked up to the coil.
The car has not got an immobilizer, Ive had my electrical tester on the coil, thats fine and the three wires coming into the dizzy, two show earth and one shows live?
Ive looked through the receipts I got with the car and the ignition barrel by the steering was changed in 2004.
ANy other suggestions guys?
Thanks so far.
I think the three wires should be earth, trigger wire to the ignition and feed to the rev counter. but I could be wrong.
Has anyone got a wiring diagram for the ignition???? Or know where I can get one from?
Thanks again
All info is v much appriciated and hope I can get her going again.
Rob
without sounding too stupid, where do you mean by ignition switch??
Where is it based? as I said earlier the ignition barrel has been changed.
Thanks for the posts though
Keep them coming
Rob
the ignition barrel is what you put your key in the switch is behind that and the contacts can corrade over time so the car will not start
do a search for "ignition AND switch"
Thanks is there any way of testing it before I buy one???
Would it still crank if the switch has gone??
There is no delay in turning the key and the engine attempting to start???
they`re only £20 from VW
yeah will still crank just not fire, on mine mechanic touched a live wire to the coil and it started on the button
