DanVW
Supercharger small belt
Sorry if this has been covered before, have searched but cant find anything! Any fellow G60 owners changed your chargers small toothed belt? How easy is it, I am sure I read somewhere that these are cheap and easy to change an therefore should be changed once a year, I also heard that if you have a Jabba charger (like me) you should change it as they have a habit of not changing this belt when they are rebuilt?
Cheers all
Dan
im sure jabba would have changed it....its all the cheap bits they put inside you need to worry about
as for swaping the belt...turn the pulley and you will see both shafts have a notch , the notches need to point at 12 o clock and line up with a line cast into the case...spin the charger by hand to confirm you got it right before starting up
Cheers Steveo :-) knew it would be easy! Just another quick one so I can plan roughly how long it will take.... Will I need to take the charger off the car to do it?
Dan
you can leave the charger on, but you need to remove the main belt to gain access, the pulley needs to come off too
i also took the airbox out to make things easier....took me well under a hour all in
