strimmer
Audi TT Black Leather Seats
possible?I read that some of you have welded the subframes from standard Corrado seats to Recaros, will this work with TT front seats? Can I fit the rear seats from the TT into a G plate corrado 16V :?:
JIMMI has got TT seats in his, hed be the man to chat to....
Dont know about the rear bench, i believe hes gonna cage his.
That sounds smart. Do you know if the height off the car floor is similar doing this as I would like to keep the same driving position. Do they weld on inside the car, do I have to cut out any of the current shell?
I fitted the TT seats and they work very well. Mine are bolted to a 5mm steel strip that sits on the lip of the runners. With the TT seat in the fully down position I find that it is approx equaly to the second to bottom setting on the std seat.
