Rado16v
Am I missing anything for VR 288mm conversion?
Just picked up these calipers, been told they're off a P reg Golf VR.
I know I need disks, pads and flexi hoses for said car. I think I'm missing the banjo bolts, will these come with the flexi hoses? I'll be using standard VW hoses.
Probably a stupid question, why can't my current hoses just connect straight up to the caliper?
Thanks in advance.
Amit
yup, banjos missing. If your using VAG hoses then simply order them at same time. You then just need the disks and pads then your off!
Your standard hoses match the ones from a Passat and the Golf ones are different...
Good opportunity to go braided...
