littlebear
Idle problem
Where the throttle cable hooks to the throttle body (and I will put a picture up later. cant right now working) there is what appears to be a plunger that holds the throttle in place at idle. Fist off what is that part called? Second mine I believe is going bad cause I cant adjust my idle any lower then 1500rpm and then sometimes it drops to under 800rpm it very irregular. Does anyone have any advise?
Mine actually was a pretty easy fix my MAF plug had gotten loose somehow. It looked like it was plugged in but it really wasn't I plugged it in and vroom vroom she prrrrrrrrs like a kitten
the MAF is right behind the air box. it is the only sensor on the air intake. when I get home I will take some pictures and post them for you.
